Create a sheet (5" x 6") to embed into a 8 1/2" x 11" sheet of paper
seandelwhitford
seandelwhitford
Hi everyone!
I'm wondering how to create a 5" x 6" sheet that will always fit onto a regular sheet of paper? It's for various site plans for a report that requires the image to be this size.
Thanks for any input!
Alfredo_Medina
Create or modify a title block that has an outer rectangle of 8 1/2" x 11", then create another rectangle inside, that is  is 5" x 6", and keep all the titleblock info within the smaller rectangle. Then print > letter size > portrait. That's all.
syman2000
I would use fit to page unless you want it to be precise with the zoom factor?
seandelwhitford
Thank you, this is the direction I need to go. Haven't finished yet but
wanted to let you know that I'm now barking up the right tree at this point.
