Create a Reveal Profile for a wall opening Rebate
alejandroCH79K
alejandroCH79K
Hi Team,
At the moment, I am working with walls with openings for windows and doors.  I am creating the jamb and the head with the tool Architecture-component-model in place- void and cut (one by one). Is there a way I can do it with a profile in the reveal?
ralphdenhaan
I recommend creating a void family with the desired profile instead of using In Place components. This allows you to be more flexible and efficient in future adjustments.
Select Accept as Solution and Likes are always welcome.
Ralph den Haan, (Lazy) BIM Specialist
LinkedIn | LazyBIM Blog
constantin.stroescu
Create a Door or a Window Family without modeling the frame and the sash , but only the opening...
I n order to obtain a more complex border profile, once in Window or Door (as you like to choose) Editor, first Delete the Opening and create a Void instead.
I attach an example of such an opening which I've created for an historical building (a Window Family in my case) I've used a combination of a Void Blend +a Void Extrusion....
Constantin Stroescu
alejandroCH79K
I'll give it a go. Are there any steps to follow? I'll do my research as well. I'll tell you if I get stuck
thanks
alejandroCH79K
can I use this one for a concrete wall? I pretty much want to cut (rebate) the concrete. I'll give it a go
constantin.stroescu
some examples:
  • by using a Wall Based Family:
  • and by using a Window Family
Constantin Stroescu
