Create a "view region" on elevation to show substructure
Is it possible to create a "cut out" view region on the elevation to control visibility option for it? I want to show the substructure of the cladding on my building, something similar to the attached picture but couldn't find any tool for that. Thanks for the help!
Accepted solutions (3)
RobDraw
I think you are going to need two views and overlap then on a sheet.
Rob
You can create parts from the wall, split parts where the cut line is, then exclude or hide the parts you want to "peel" off.
Thanks guys, I hope there is something like "plan region" or something for elevation, but this confirmed my thought that I need to do some extra work to make the substructure "appear" behind the panel.
Another approach you can use is to Split and Jog the Elevation's Cut Plane as shown:
