create a lookup table, parameter names are case sensitive
Message 1 of 12
i want just create a plane as per the size thickness should select from table, details are attached please help
Replies (11)
Message 2 of 12
martijn_pater
Sure you're not looking for a type catalog?
Message 3 of 12
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2018/EN...
Here's a much better one.  Just for fun, count how many time the guy says "confusing" or some variation of the word "confusing".
https://www.youtube.com/watch?v=USqZc-VE95Y
Message 4 of 12
Please review my screen shot
Message 5 of 12
The Lookup Value has to be in the First Column.
Message 6 of 12
This table I created same way,
Message 7 of 12
We have
L, W, thickness. So we column is thickness,  look up value L
Can you please check formula?
size_lookup(table,"thickness", 100mm,L)
Message 8 of 12
Honestly, I don't know how the heck this works or what you expect it to do, but your first mistake is the first value. Should be "look up table" not "table".
Message 9 of 12
martijn_pater
You should watch the video @barthbradley added, see if that helps you. Also you are using a type parameter, whereas look-up tables generally use an instance parameter. Don't know if it matters tbh, but that's from the knowledge page...
The size_lookup function is intended for instance parameters. If you want to use tabular data to define types with unique values for each type, create a type catalog
Message 10 of 12
That file name is    table.csv
Message 11 of 12
Yes, I know.  What's your point?
Message 12 of 12
thanks dear,
the mistake which i did ,in formula i have to put parameter name of file name, now it is working.
