Create a custom ceiling with a 3D void pattern like a wood slat ceiling
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Is there a way to create a ceiling family that provides an actual 3D pattern like a suspended wood slat ceiling(see "wood slat ceiling example.jpg")? We can use a .pat file to create the correct pattern, but it does not show up in 3D. Modifying the ceiling boundary for each slat is far too time consuming if ceilings are not rectilinear, and we have many unique ceiling shapes (see "ceiling capture.jpg").
I have also seen posts about using a sloped glazing element and customizing the panels. This idea sounds good, but it has many problems in terms of collaboration work flow because it will not be classified as a ceiling.
The other idea we had was a parametric family that will define height, width and spacing of the wood slats, but I do not know if it is possible to create a custom boundary for a family that is not a system family.
Any ideas?
Thanks!
