Corrupt file - Assertion failed: line 561 of UndoMgrInterface.cpp
boostyourbim
boostyourbim
Revit 2018 crashes trying to open this file.
'C 14-Nov-2017 16:29:05.955;  10:< Assertion failed: line 561 of d:\ship\2018_px64\source\revit\revitdb\undo\UndoMgrInterface.cpp
Please report this to the Dev team and let me know how this might be avoided while I wait for a fix, hopefully in 2018.3
yurikim
Thank you for your posting @boostyourbim. Try this file and see if this helps.
I couldn't see the same lines as you in journal though. Did this happen after Undo command?
Yuri Kim
Product Support Specialist, AEC
boostyourbim
Thank you for your quick reply and repairing the file!
However, I need to understand if there is any way I can avoid this corruption. If it is caused by the contents of the file or the API command I am developing, I need that resolved before I release this product to my customers.
Regards
Harry
yurikim
Thank you for your reply @boostyourbim.
You might want to check this forum to get more help on your codes:
https://forums.autodesk.com/t5/revit-api-forum/bd-p/160
Yuri Kim
dcarlson
Is it possible to get more information on this issue? We're experiencing this problem with a project on BIM360 and have been unable to resolve it. Do we need to send the project somewhere to have it fixed, or is there a way we can do this ourselves?
