Announcements
Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
corrugated Metal Curtain wall panel projection lines
3 REPLIES 3
dreese
505 Views, 3 Replies
Hi all,
see attachment of image and curtain wall profile .rfa
I've created a custom curtain wall to display as corrugated paneling using a curtain panel family with an extrusion of a single "rib" for the panel.  the issue i'm having is, i'm trying to make colored elevations with constant color display. the panels are of a dark color and, when i apply the material to the panel it displays the correct color but, the projection lines all show as white. i can use the linework tool to manually adjust each panel but, as you can imagine that's a lot of work. i've tried to override graphic in view, override visibility settings of curtain panel projection lines, no luck.
any help would greatly be appreciated
Dillon
3 REPLIES 3
in reply to: dreese
Post the RVT
dreese
in reply to: barthbradley
Hi barthbradly,
i cannot post the project .rvt file for client confidentiality reasons. i did however copy the curtain wall to a new blank .rvt template file, created a shaded view elevation and, the projection lines display correctly in this file.
dreese
in reply to: dreese
Ha! figured it out.
i had a visibility filter for curtain panel on my hidden line views that display the projection lines as halftone. i didn't realize the filter was still on.
Thanks for helping me solve my self inflicted issues  🤔
