Corner Curtain Wall Mullion
Hi everybody,
i am having trouble building a corner curtain wall mullion. its probably a common problem, but i couldnt find a satisfatory solution for it yet.
the idea is to build 2 halfs, so that each wall has its own vertical corner mullion (the vertical mullion should be the continuous one).
problem: the horizontal mullions dont join properly to the vertical ones.
does anyone knows the solution or a clean work around?
Thanks!!
hello
please, can you provide us with your working file so we can examine it to see what is the problem ?
the reason that you haven't found a solution is because there isn't one that works consistently. I am a curtain wall detailer and have been using Revit for over 8 years. I gave up on profile driven corner mullions years ago. I now use parametric GMs for corners. They allow Revit curtain wall to join at corners correctly and look correct in all views. Good luck!
