Corner beam -- any direct way to project a side beam on a 45 degree face?
heichan88
heichan88
Hello
I made some side beams facing the front (parametric generic model), then want to create a corner beam which is projection on a 45 degree face, any direct and simple way to make it? I tried mass form but it is also complicated because these beams are attached and flexed with other separated forms with complicated shapes,
Let's see the RVT. Post it here.
heichan88
Hello @barthbradley
Pls see rfa,
(1) the parameter change by selecting "type" then formulas follow, quite complicated,
(2) meanwhile, it is cut by several external parts (also flex)
(3) as it should be arrayed and duplicated, so external families is needed rather than in-place model
 (2)
