(duplicated to be deleted) how to make a corner beam by projecting a side front beam on a 45 degree surface plane
1 ANTWORT 1
Nachricht 1 von 2
heichan88
195 Aufrufe, 1 Antwort
Hello
I made some side beams facing the front (parametric generic model), then want to create a corner beam which is projection on a 45 degree face, any direct and simple way to make it? I tried mass form but it is also complicated because these beams are attached and flexed with other separated forms with complicated shapes,
1 ANTWORT 1
Nachricht 2 von 2
als Antwort auf: heichan88
Let's see the RVT.  Post it here.
