Copying Tags from a different project
Message 1 of 14
I would like to copy the tags from a different project to the project i'm currently working on right now. I did the Transfer Project Standards already but it didn't really copy the tag notes from the other project. How do I copy that? If there is no way of doing that, how do I add tag notes in my project? Currently when I do tag by category, the text just shows a question mark.
Replies (13)
Message 2 of 14
iainsavage
I think the parameter in the fixture is not populated with a value so the tag can’t display the value.
Message 3 of 14
hmunsell
You are likely missing a Project Parameter or Shared Parameter in your model that the Tag is using.
when you did a Transfer Project Standard what categories did you select?
Howard Munsell
Message 4 of 14
I selected all of the categories
Message 5 of 14
alan_eu
It that a Type Mark or mark label? Probably the problem isn´t exactly on the tag, but the information on your family.
I suggest you click on edit family to see what label is on the tag and come back to input the necessary information. Would be faster to input those on schedules.
Alan Araújo EESignature
Bee1ColabInstagram Alan Araújo RevitBee1ColabGrupo Whatsapp
Usuários do Autodesk Community:
  • Se a resposta resolveu o seu problema, clique em Aceitar como Solução! isso ajuda os outros usuários a encontrar rapidamente uma resposta e Curta se gostou 🙂
  • Manda um alô nas minhas redes sociais com +600 vídeos de de Revit/BIM, Templates e conteúdos semanais! Gratuitos! 🙂
Message 6 of 14
how do I add the parameter value?
Message 7 of 14
hmunsell
@iainsavage your probably correct. if it was a missing project/shared parameter the "?" would be red.
Howard Munsell
Message 8 of 14
alan_eu
Not exactly missing... just not filled up...
Message 9 of 14
Lance.Coffey
Autodesk Support
Autodesk Support
To identify the parameter that is being read by the tag, go through the following steps:
  1. Select the tag.
  2. Edit the family and then select the label.
  3. Edit the Label.
  1. Once you have identified the parameter that is being used (in the example above it is Type Mark), cancel editing the label.
  2. Go back to the project.
  3. Select the object you are tagging.
  4. Review the properties (Instance or Type) for the item you are tagging and ensure that the parameter has a value set.
Lance Coffey
Technical Support Specialist
Message 10 of 14
jbrazier
Are trying to get the value in the tag such as the "M26" value for the toilet?  If so those values exist in the element your tagging not in the tag, in this instance from the toilet.  Look at the Type / Instance Properties of the toilet in the original project and you should find a value that reads "M26", that's the perimeter that populates the tag, you would have to apply that value to the same parameter in your current project.  Tags read from parameters in the tagged element, they are not text.
Jon Brazier
Director of Production Technology
O'Donnell & Naccarato
Philadelphia, Pa.
Message 11 of 14
iainsavage
As @jbrazier said.
Message 12 of 14
Danielm3ZTU5
This is not the answer on the question. I have the same problem. How to move library of tags from one project to another?
Message 13 of 14
RSomppi
Then you have a different problem.
I think you mean copy, which is easier said than done, AFAIK. Most people have a family library for easy insertion or they have them in their project template so that they are preloaded into any project started with that template.
You would need to have a view with the tags that you want to copy placed in it, then a copy/paste into a similar view will get the families into your new project.
Message 14 of 14
SteveKStafford
Assuming you're interested in having a "library" of those tags, "harvest" the families by, viewing in the Project Browser > Families, using right click > Save Family to save the family to a folder of your choosing. Then you can use Load Family and select all the families in the folder to add them to any other project you need them in. As mentioned earlier, you need to consider that the tags might use/refer to shared/project parameters that will also need to be defined in project so the tags will work. Ideally you'd put all of the tags in your project template(s) so that task isn't necessary very often.
Steve Stafford
