Copying Rebars
Copying Rebars
Copying Rebars
I am having a problem everytime I copy a rebars, the length varies as I go on copying...anyone who could help me...and how can I unjoin rebars in revit without using other application..thanks!
Luiscko
If you only want to use Revit this is the only way that you could do, obviusly i recomend you copy from the original element short from the larger one if you want to control better your changes. I recommend you personally usign Dynamo to improve your time doing that.
Luis Rodríguez
BIM Manager | Digital Transformation Lead
alt="EESignature" width="244" height="22">
Your Name
Encontraste util este post, compartelo y dale like para que llegue a mas personas como tú.
Si tu respuesta fue solucionada, te agradecemos que des click en el boton SOLUTION.
