Copying Ceiling Tags
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm finding that copying Ceiling Tags can produce undesirable results. Revit has a hard time finding the right ceiling. When you have varying ceiling heights you can't count on the Tags even showing the correct ceiling height. You can activate all the leaders and check if the arrows lead to the correct sketch boundary, but that's more work than it should be. You can also check the host one by one, but again not something you'll like to do when you need to finish up somebody elses plans.
When you copy a Ceiling Tag, Revit doesn't always find the correct ceiling. Sometimes it does, sometimes it doesn't, sometime it refuses to copy the Tag altogether. I've include a simple metric project with an example of the problem and two screenshots that should show how to replicate the problem.
Why would you want to copy a Tag instead of using "Tag all"? Well, because "Tag all" just throws those Tags onto the plan. The Tag might hide certain lighting fixtures, it might not be positioned on the actual ceiling when the centre of gravity is outside of the sketch and can show the wrong height anyway. You'd have to check every single one which is more work than just placing them one by one in the first place.
Placing them one by is also a pain because you like to have them all nicely aligned to the pattern (especially with ceiling tiles) whiwh is also more work than it should be.
How are you all faring with Ceiling Tags? Happy with the way they work now?
