Copy monitoring levels transferring elements
AidanHawkins
AidanHawkins
I have a structural model and an architectural model where in the architectural model, the levels are not copy monitored so I can see both levels in elevation view. The architectural model is fully modelled however now I want to copy monitor the structural levels and delete the architectural levels. however, when i go to delete the architectural model levels it says it will delete all the elements I have created. Is there any way I can move these elements to these new copy monitored levels or how does it work?
Edwin.Rense
Do the levels have the same name?
Can you change the architectural levels to 'not building story' and the Structural to 'Building story' before deleting, is the geometry being saved?
Does that do anything?
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Kind regards,
Edwin Rense
Cadac Group AEC BV
Supporting Consultant AEC
Cadac Group .
AidanHawkins
Do the levels have the same name? Yes
Can you change the architectural levels to 'not building story' and the Structural to 'Building story' before deleting, is the geometry being saved? Yes, I did this and the geometry is still saved when changing over the building story tick mark
I now want to delete the levels in the current architectural model, however when I go to delete, tells me I will delete all the geometry.. so it still doesnt solve my problem
Please see image below
Copy monitor levels is a step you do prior to model anything.  There no point doing it after you already created levels and model elements related to those levels.
Edwin.Rense
It seems like the architecture levels can't be deleted without deleting the hosted objects.
Why not 'simply' align the architectural levels to the structural levels so they obtain the correct elevation.
This way the levels move and the objects hosted move with them.
If you don't want the objects to move but remain on the 'old' elevation you should not move the levels but simply hide them in your architectural model.
Kind regards,
Edwin Rense
Cadac Group AEC BV
Cadac Group .
AidanHawkins
I know, unfortunately I modelled this last year when I wasn´t aware of this
