- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
We are using a structural engineer for a project we're working on that has drawn his structural shear walls, shaft walls, and columns in revit. We have copy/monitored all the columns, shear walls, and shaft walls.
What doesn't seem to work for us is when we try to change the wall to a different type (even though we keep it "core centered" - AND keep the core the same) the wall moves and changes "wall centerline". It's then reported as a coordination issue to be resolved. if you tell the wall to update to match the linked file - the wall is then moved and the core centerlines do not match. If you ignore the error how do you keep track of what walls your supposed to update? The update could have been from when the engineer relocates the wall versus from when you changed your wall type.
This behavior seems to be standard in both 2015 and 2017.
As a result, we are copy/monitoring structural walls, apply an "exterior partition" and an "interior partition" to each wall. This means each wall type is potentially 3 different wall types when it comes to tagging. We've got an in-office work around in which we are only tagging one of the walls... however, what is the point of using the copy/monitor feature if all we can do is use the exact wall that is originally drawn?
Is this normal? Am i doing something wrong here?
