Copy Monitor From MEP Results in Resetting Instance Parameters and change in Host For Some Elements
haljari
haljari
Hello Every One I am trying to copy monitor from the MEP Files into my architectural Model , Resulting in Resetting instance Parameters for Power Sockets or some times changing the Family into another type , and for the Mechanical Families Some times it changes the host and changes the length for the AC Grills , any suggestions ?
Kindly Check the photos attached below
It's a limitation. Custom Instance Parameters do not copy. Only Type Parameters.
haljari
so there is no workaround for this ?
