Copy Elevations without Creating New Elevation Family/Marker
BigPicture045
BigPicture045
When I right click and select duplicate for a Elevation, Revit creates a new building elevation family marker in the same place. I have moved it over to show the two separate elevations families:
Is it possible to duplicate using the same elevation family? I do not want to have multiple elevations as it gets to be confusing for other users. I want a working and documentation elevation using the same marker.
RobDraw
No can do.
Rob
Different elevation views must use different makers but you could hide the marker(s) in view if you want.
Mike.FORM
You can make a "Working Elevation" view type and then use a filter to hide them all in your documentation floor plans.
