Coordination : Openings
XXalessio.amodioXX
Message 1 of 8
XXalessio.amodioXX
Hi all,
To prepare the opening for coordination between disciplines, do you use a out of the box Revit tool or you prefer model the openings manually?
Replies (7)
Message 2 of 8
What do you mean by "prepare the opening for coordination between disciplines"?
Message 3 of 8
XXalessio.amodioXX
e.g. there is a pipe passing through a Structural wall.
This is an opening.
Message 4 of 8
TripleM-Dev.net
A family with a solid mass would be preferable.
Reservation objectsReservation objects
- Michel
Message 5 of 8
XXalessio.amodioXX
Do you manually place there ?
Edit
And ho do you schedule them?
Message 6 of 8
TripleM-Dev.net
These specially are placed by a app. But can also be placed manually.
In you're case the required space may be larger than the modelled elements, a workspace around object or ability for montage/removal of items. So you would need to manually place objects representing the space/opening you need.
Schedule?, there objects so they can be scheduled by their category and a parameter indicating it's a OpeningElement.
- Michel
Message 7 of 8
This is an opening.
Are you asking about how to perform an Interference Check?
Message 8 of 8
XXalessio.amodioXX
I am looking for a valuable but not so expensive app
