Coordination Model Line Accuracy
Hi guys,
Im having a problem with an imported Coordination model with it not importing accuratly causing this skewed lines.
Any ideas on how to fix?
hmunsell
there is a lot to see in that image, which "skewed lines" are you referring to? 🙂
Howard Munsell
kadmonkee
try linking the file into Revit, check the units from the source file match the units in Revit,
if importing is causing issues.
confirm the source file is accurate.
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
