Converting mass face to roof
Any chance I can convert this face to roof without simplifying it?
Because right now all i found is that this geometry is too hard for revit to understand.
Making walls not an option here.
Thanks for your opinions.
Why is wall out of the question?
Maybe just insert the Mass into an In-Place Component with Category Roof and assign a Material to it.  Obviously, you'd need to hollow it out first.
Can you share the mass?
Thank you guys !!
Finally found a solution to this with Dynamo.
Tried it and it worked.
Anyway thanks.
Post the dyn routine.
