Convert to .rvt file
Any kind person can help to convert the attached .rfa file to a format that can be import into Inventor? Either .rvt or .step. Your help is much appreciated. Thanks in advance.
Regard,
CK
Can't you load the family (RFA) into a blank project (RVT) and open the project file in Inventor?
Here's a SAT and RVT file FWIW:
Thanks for the help. Would have do so only if I have Revit installed.
Hi @barthbradley ,
Do you able to give another help? I have anther file file in .rfa format that need to covert to .step format.
Much appreciated if you able to help again.
BR,
Ck
syman2000
See attached
Thanks for the help. Much appreciated.
