convert face-based to non-hosted family
HVAC-Novice
Mentor Mentor
Message 1 of 13
HVAC-Novice
These instructions (after 10 minutes in the video) show how to convert a face-hosted family into a non-hosted family. This is done by deleting the host. the problem I have with my R2022 family (attached) is that I can't delete that host. As the screenshot shows, the delete options are grayed-out.
Am I doing something wrong or is there a different way to make this an un-hosted family? And I don't mean re-creating the family 🙂
Revit Version: R2026.4.2
Hardware: i9 14900K, 64GB, Nvidia RTX 2000 Ada 16GB
Add-ins: ElumTools; Ripple-HVAC; ElectroBIM; Qbitec
Replies (12)
Message 2 of 13
Can you change the extrusion thickness to ZERO?
Message 4 of 13
syman2000
Any reason why you wouldn't simply create new family, load that face base into new non-hosted family and let it host on workplane? I find that works instead of deleting the host and cause more issue down the road.
Message 5 of 13
There is a tool in pyRevit that does this conversion in one click.
Message 6 of 13
RDAOU
@HVAC-Novice
I agree with @syman2000 ... developers usually tend to add features not remove them. If it was seamless and/or it is supposed to be deleted, why would they disable that option?
Not sure why you need it non-hosted; however, if that's what you want, then nesting the face-based into a non-hosted Lighting fixture template is the headache free option.
Message 7 of 13
Why the gymnastics? Just zero out the depth of the host extrusion to delete it and the Face-Based Family becomes becomes a Work Plane Based Family.
Message 8 of 13
RDAOU
@barthbradley ... maybe for you nesting one family into another falls under gymnastics but for me it is a fail safe practice.
Besides that, I prefer to give the developers the benefit of the doubt and not advise others to force an action which Autodesk seems to have intentionally disabled a few versions back.
Message 9 of 13
Disabled? What was "intentionally disabled a few versions back"?
Message 10 of 13
RDAOU
Yes...why do you seem surprised? You didn't know?
Message 11 of 13
HVAC-Novice
That actually works and makes the host deletable and the family un-hosted.
I still have the problem that the fixture is 90° off and I can't turn it to be horizontal. So maybe I have to re-create.
Reason I want to avoid a new family is I need to recreate the type parameters inc ies files. Not undoable, but a hassle and prone to introduce errors.
There are many reason to have a family un-hosted. in this case i want to place them without poles. i only do the site-lighting calcs and don't want to worry about poles. Especially since I need to play around with fixture heights for best lighting.  with the face-based fixture, i also need to include poles, which I don't really need and make it less flexible.
Since there is a workaround to make families face-based, and non-hosted, I suggest Revit could just add a button to do that. Families I start out with, often have odd hosting settings (i.e. ceiling hosted, when face-hosted is much more flexible).
Message 12 of 13
HVAC-Novice
Unfortunately our IT and attorneys don't just allow installation of software. They require a lengthy approval process and free or cheaper add-ons don't provide all the documents our IT requires. So I'm limited to whatever is included in our AEC package, or a very expensive add-on where the vendor provides that information. It really would be easier to create many new families from scratch 😁
Message 13 of 13
peter_sharrock
Community Visitor
Community Visitor
no, its a wall
