Controlling leader line location for annotation families
Brianna_Dixon
Brianna_Dixon
I have a finish tag family with a "large" type and a "small" type. However, whenever I add a leader to the small tag, it attaches to the corner of the large tag, even though the large tag isn't visible. Is there a workaround for this, aside from having separate families for the difference sizes?
jmendezicce
you add a Leader inside revit family?
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
Si esto ayudó a resolver su problema, recuerde "aceptar como solución" para ayudar a otros a encontrar respuestas.
Create two separate families.
jmendezicce
use the same geometry, add parameter dimension and create types family, do not use yes or no parameter for geometry
lucdoucet_msdl
@Brianna_Dixon
One family with 5 types: 1 Large and 4 Small with extra lines to "extend" the automatic leader lines automatically generated by Revit. Downside: the user has to remember to change the family type everytime they change the position of the leader line.
Can you explain why it is you have two sizes of symbolic tags when they automatically scale with respect to the view?
I know why I would have use for two seperate sizes but it seems more of a hassle to have to have 5 types in a single annotation tag family rather than two seperate annotation tag families for large and small sheets/presentations formats.
Hope this helps,
-luc
