controlling arc length of a sweep
kgatzke
kgatzke
Why have you made this so difficult to accomplish?
I want to control the length of a sweep defined by a path consisting of a single arc.  I want one end of the arc to remain fixed.  I want the other end to move towards and away from the fixed end ALONG the arc so the radius remains fixed.  I tried parameterizing the arc length.  I can only get a reporting parameter.  I tried reference planes controlled by an angle parameter.  I got a constraint error.  I tried reference lines.  At first the parameter would always move the pinned line (really?) and then I followed the advice of this post but the arc hops around (at least the radius remains the same).  I tried aligning the fixed ends of the arc.  I got an overconstraint error on the sketch.
There has to be a way to do this.  Your programmers aren't so daft they concluded no one would ever want to control arc length.
SO HOW DO I DO THIS?
BIM.Consultant
Check attached family. If you need any clarifications please ask.
Alfredo_Medina
I think @kgatzke wants to drive the arc by the length, not by the angle. Maybe the family requires the addition of a formula that receives input for the desired length, and, based on that length, the formula outputs the required angle.
kgatzke
Angle works for this use, but length would be better since it gives me something that can counted towards material takeoffs if I needed to go that route.  I don't in this instance.  The angle method described above works, though not with the subtended angle.
There's a trick, though.  I was having constraining problems because I kept trying to align the endpoint of the arc to the line/plane/etc. which resulted in constraint errors.  I tried extending-to the plane and that worked parametrically.  I did not expect that or try it sooner because I assumed extend-to was a one time thing and wouldn't stay joined.
Alfredo_Medina
@kgatzke wrote:
Angle works for this use, but length would be better since it gives me something that can counted towards material takeoffs if I needed to go that route.  ...
OK, so just in case you need to control the arc by the arc length, this is how it works:
 You enter a value for the desired arc length (AL) and the formula calculates the angle (B), as shown below.
The formula for angle B is = AL * 180 / ( pi() * R )
