control yes/no parameter in title sheet with global parameter
HVAC-Novice
Advisor Advisor
HVAC-Novice
I added a "for construction" watermark to my title sheet based on this video.
the watermark visibility (a text in my case) is controlled by am instance yes/no family parameter. If I make this an instance family parameter, I have to turn it off for each sheet.
But for my projects ALL sheets start out with this watermark, and once the bid set is finished, I want to turn it off with ONE setting for ALL sheets at once. My idea is to tie that to a global parameter. But how? I didn't see a way how to do that.
My best workaround is to instead of making the visibility an instance  parameter, make it a type parameter and then I change that checkmark in the in "edit type" for the title sheet family. It kind of works, except for the cover sheet and regular sheets I have separate title sheet types, so need to do it at least twice.
Revit Version: R2026.2
Hardware: i9 14900K, 64GB, Nvidia RTX 2000 Ada 16GB
Add-ins: ElumTools; Ripple-HVAC; ElectroBIM; Qbitec
HVAC-Novice
OK, i think i figured it out. Making it a type parameter allows me to tie it to global parameters. Just not sure why that doesn't work for instance parameters.
Edit: it works for instance parameters. But I have to tie it to the global parameter for both of the sheet types.
