Control of line weights
Greetings,
I'm having an issue managing line weights the way I want. I know you can control them via Line Weights window, but what I want is
- annotation lines stay at 0,1
- model lines at fe 0,18 BUT hatches of walls, insulation etc set to 0,1 and i cant hatch them with 2d regions as it is Quite a big project
The reason behind this is that I'm exporting my views in 1:75 scale and I want better visibility overall.
I'll be very grateful for any advice 🙂
Ilic.Andrej
Besides controlling Line Weights, explore Object Styles on the Manage tab.
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
I want to change weight ONLY on hatches of walls etc. not lines on walls inself, so I really don't know what should I do with Object styles.
Ilic.Andrej
Read this post.
This guy is playing with Dynamo.
Maybe it will help.
Andrej Ilić
MSc Arch
Nurlan-A.
One of the best practices is to set the line weights from 9 to 16 the same size for all scales. This way you will have two ranges of line-weights: scale-dependent (1-8) and constant (9-16). Then use 9-16 in you case.
Ugh I was hoping for a simple solution but I will give this a try.
Thanks 🙂
