Control Default Family Type with .txt file
3 ANTWORTEN 3
Nachricht 1 von 4
bcampbell11
245 Aufrufe, 3 Antworten
Is there a way to control the family type that loads when loading a family though the FamilyName.txt file?
Instead of going into the family and setting the type to current and saving?
Example of a family below, any trick like putting an asterisk next to the one you want to always load as default?
,W##other##,A##area##inches,d##length##inches,bf##length##inches,tw##length##inches,tf##length##inches,x##length##inches
MC18X58,58.0,17.1,18.0,4.20,0.700,0.625,0.862
MC18X51.9,51.9,15.3,18.0,4.10,0.600,0.625,0.858
Thanks!
MC18X45.8,45.8,13.5,18.0,4.00,0.500,0.625,0.866
MC18X42.7,42.7,12.6,18.0,3.95,0.450,0.625,0.877
3 ANTWORTEN 3
Nachricht 2 von 4
BDMackey
als Antwort auf: bcampbell11
If one isn't selected via the Type Catalog then it will use the default in the Family.  This is why the only type in my family is "See Type Catalog for Additional Sizes"
Nachricht 3 von 4
bcampbell11
This may be silly question, but is there an easy way to modify the default in the family?  Or is the first type that was created in the family?
Thank you!
Nachricht 4 von 4
BDMackey
If a family has multiple instances and is loaded into the project all those instances get loaded into the project. There isn't really a default.  If you are talking about when I click the "Door" command what is the default used then that is the last one that was placed with in the project.
