Contour label is blank and hijacks screen
sascari
Message 1 of 11
sascari
Revit 2020.2
When I run the "Label contours" (from Massing & Site > Modify Site) I get a dash line on a topo but no contour labels. The labels are blank. I cannot deselect it or pan away. I've never experienced this before. Can anyone advise please. Thanks.
Replies (10)
Message 2 of 11
You probably have them  turned off. Open the Site Settings Dialog Box and check.
AND/OR:
Message 3 of 11
sascari
Just checked. Type properties are fine, labels are on. I can see the dashed line, but I cannot deselect it. It only happens in this file. Made a new file from scratch to test it out and had no problems.
Message 4 of 11
What is the interval between those contours?
Screenshot your Site Settings.
Actually, just post the booger RVT.
Message 5 of 11
sascari
See attached. I can try to post the RVT file in a sec.
Message 6 of 11
sascari
@barthbradleyFile is attached.
Message 7 of 11
What am I looking for? The only contours I can find to label are these:
Message 8 of 11
sascari
That's the crux. I can't label any contours. As soon as I initiate the label tool the screen isolates into that and I can't deselect it. Could the fact that I'm working remotely have an impact? I have 0 issues otherwise.
Message 9 of 11
sascari
I'm attaching a GIF screencast of the issue for reference.
Message 10 of 11
Go to your Plan View named DEMO STORMWATER CALC and try labeling the contours. Are you able? If not, your issue is a local one.  Does it happen in other Projects?  If so, maybe your installation needs repairing or you have a "bad" Add-in.
https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/How-to-reinstall-or-repa...
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/sfdcarticles/sfdcarticles/H...
edit: Can you label contours is any of your Projects Plan Views where the Topo is visible? How about newly created Plan Views?
Message 11 of 11
sascari
Thanks @barthbradley . I think it's localized to this file because I can get it to work on new projects. I did try it on a new floor plan with same results. I'm kinda stumped...
