- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Dear all,
I was trying to make a rotatable bi-folding door that allows flexible length and rotation when inserting to a curtain wall system.
here is my strategy :
1. make a single panel that allows flexible length and adjustable rotation with a sweep mass;
2. mirror the panel and constraint with same angle which will form my second level of family;
3. place the family in the curtain wall door family with array to do the courting work; use 'visibility' to hide the last panel if the court is in odd number.
my question and difficulties are as below:
1. Is the strategy for such bi-folding system valid? is there any better way?
2. is there any easier way to do a mirror array for single panel which can eliminate the 'visibility' option?
3. I am now having a problem when setting up the first panel, I am not able to constraint the startup point (0,0) with the panel i have developed. It works well when i tried to rotate and add frame width, but start flying away when i flex the panel length.
Thanks a million for your sincere help.
Leonard
