Connecting stairs to levels
Message 1 of 9
Hello I'm trying to figure out how I can connect my multistory stairs to each according level. When I clicked the levels button the stairs are off. If someone could tell me how to fix it I would appreciate it. My project is below. Thanks
Replies (8)
Message 2 of 9
Sahay_R
In Revit 2018 there are some pretty sweet multistoried stair tools. Select the stair, and attach to levels (I'm not at the office, so I can't give you a screenshot)
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Message 3 of 9
I did the multistory stair option and it projected it to all of my levels but its not connect the stairs the right way. I'm in Revit 2018
Message 4 of 9
There is no stair in the one-story building you attached.
Message 5 of 9
Sorry attached he wrong link
Message 6 of 9
Attached the wrong link here is the right one
Message 7 of 9
Message 8 of 9
For some reason its not letting me edit the stairs to connect them. Could you possible take a look at them. There are 3 total stairs.
Message 9 of 9
For the multi-level stair you need to TAB to select A stair before you can change the dimensions.
The other two stairs below are quite screwy.  Everything is wrong.  I fixed one just to show the correct height but I suggest you re-model them from scratch.
