Connect walls with different height
cadedu22
cadedu22
Greetings,
How can I make wall go all around with same texture like this:
Lower the Cut Plane of the View.
...before:
cadedu22
Quick and clear, thanks bud.
...I forgot about cut plane
RDAOU
@cadedu22
Setting the cut plane too low might affect the visibility of other elements on that plan view ...You might want to consider adding a Plan Region within the finish boundaries of the walls and resetting the view range of that to 1200mm
cadedu22
On the point, this was my next question.
Thanks.
