Conditional Statements - reading information from another parameter
yuliya.nenovaWUZQN
yuliya.nenovaWUZQN
Hi everyone,
I have a door schedule where I want to show the wall material and thickness in a "combined" way, meaning: I want to have columns with several material types (concrete, brick, gypsum etc.) and show the wall thickness below in each door instance raw under the related material. Sofar I've created a wall thickness parameter and material type parameters as a yes/no parameter. Is it possible then, to use a conditional statement in a parameter that requires when the material is correct, to show directly the wall thickness, and when it's wrong, to leave the cell empty? I tried with if(material, thickness, "") but it's showing me wrong Unit. Does anyone know how to solve this/how is the proper structure of the formula? Any better ideas are welcomed too.
p.s. attached you can find a schedule from excel showing what I want to achieve - cells in red are material types and in green I marked a type which is showing wall thickness information - to be understand as all doors are in the same wall type with the same wall thickness.
Thanks in advance!
Are you trying to show the door frame depth or throat width? If so, you
can use a shared reporting parameter in the family to report the host wall
thickness and add it to the schedule.
RDAOU
@yuliya.nenovaWUZQN
Thickness is a Length parameter..  "" is a text field ... you cannot combine Length and Text in a conditional statement.  It has to be either / or
If you want that to work, the Length would need to be a text parameter too ie: input manually or using Dynamo.
Otherwise, instead of "" will need to be you will have to settle for the integer 0...a blank cell wont work with length
@yuliya.nenovaWUZQN wrote:
Hi everyone,
I don't understand why you want the thicknesses of Wall Types' individual layers computed and reported in a Door Schedule.  I can't think of one valid reason to include that information in a Door Schedule, but you could compute and report those values in a Wall Material Take-off.
See Calculated Parameter "Thickness" in below screenshot:
yuliya.nenovaWUZQN
Thank you very much!
