Conditional odd / even parameters associate with Lenght parameters
9 ANTWORTEN 9
GELÖST
Nachricht 1 von 10
strange4ride
577 Aufrufe, 9 Antworten
Good Evening, so my task is this one, i have a whole number parameter, and every time this whole number be odd, i want de lenghth parameter associated be "X" value, and every time be even, the length value is zero or an infinitesimal number, ive alrealdy made even and odd parameters, anda until now these lines were constructed
Parameter = X
Even = rounddown(Parameter/ 2) = roundup(Parameter / 2)
Odd = not([Even])
Length 3 = Length / Lenght 3
Now, the is a way to associate the (odd) to (Lenght 3) in a way that every time the odd parameter is activated length 3 is = the equation presented and every time is not (Odd) Length 3 is = 0?
If i dididnt manage to provide a great clarification, please be welcome to say that i try to contextualize better, thanks for the attention
9 ANTWORTEN 9
Nachricht 2 von 10
strange4ride
als Antwort auf: strange4ride
A Quick correction, the length 3 parameter is...
Length 3 = Length / Length 2
Nachricht 3 von 10
Hard to understand. Are you doing this in an itemized schedule with Calculated Parameters? That might explain a few things.
Got any screenshots?
Nachricht 4 von 10
Alfredo_Medina
Your question is not clear. Do you have a way to know if a number is odd or even? The way that you describe above, is that a formula that works, or are you just describing how it should work?
When you write: Even = rounddown(Parameter/ 2) = roundup(Parameter / 2)
What kind of parameter is Even? What kind or formula is that with two equal symbols?
Nachricht 5 von 10
strange4ride
als Antwort auf: barthbradley
Há yeah, its for a parametric family that i am programing, an generic model, an wardrobe, with pairs of dors, but i want to program a way tô show a lonely odd dor in the end If i wish on the project, Ive already made It before with other methods, but i looking for a way tô make It better
Nachricht 6 von 10
Alfredo_Medina
ok, now I have a better understanding of what you're doing. The first part is like this:
Nachricht 7 von 10
strange4ride
als Antwort auf: Alfredo_Medina
Even is the name that i gave It to the parameter, and the way that i find tô make Revit knows when some númber is even is this formula
If the númber is diferent from even "not(even)" the númber is odd
Nachricht 8 von 10
Alfredo_Medina
The other part would be like this:  (units as metric, for clarity)
Nachricht 9 von 10
strange4ride
Yeah, thanks for share the schedulle, Mine where Full of layers of parameters associated one tô another on my native linguage.
I will try enable this solution as sono as possible, thanks
Nachricht 10 von 10
Alfredo_Medina
Another way to know if an integer is odd or even is this: (highlighted)
