Conditional Formatting in Schedule - If/Then
biagioni-paulette
biagioni-paulette
Is there a way to create an if/then forumla in a schedule parameter? I have a door schedule with an existing parameter for a hardware package type. We have three "types" - 1, 2, and 3. I would like to create a new conditional if/then parameter: i.e. if Hardware package type = 1, then the new parameter would = 5, if hardware package type = 2, then the new parameter would = 10, if hardware package type = 3, then the new parameter would = 15. I think this is something Revit should be able to calculate, but I'm not quite sure how to go about doing so.
lucdoucet_msdl
@biagioni-paulette
The new values are called calculated values and the revit help link is as follows:
https://help.autodesk.com/view/RVT/2020/ENU/?guid=GUID-44EC6734-D36B-4083-8FCD-833B166D6C0A
A link at the bottom of this help article will also lead you to formulating numerical expressions with conditional statements.
Good luck
-Luc
If you original hardware type is a number or an integer parameter then yes, your formula for the calculated parameter (number or integer): = hardware type * 5.
https://revitforum.org/showthread.php/1046-Revit-Formulas-for-quot-everyday-quot-usage
Almost sounds like you are describing what we do via Key Schedules.
FWIW:
 https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2016/EN...
