Concrete volume
13 REPLIES 13
Message 1 of 14
8966 Views, 13 Replies
Concrete volume
is there a way to obtain entire concrete building volume (material takeoff)!?
Do I have to summon foundations, floors, columns etc. or is there a workaround?
Regards!
Concrete volume
Regards!
13 REPLIES 13
Message 2 of 14
Use a multi-category material take-off schedule.
Message 3 of 14
in reply to: ToanDN
@ToanDN
...tried to make a multi category takeoff schedule but something's wrong.
I should have around 550 m3 of concrete but Revit calculates "Grand total" 229m3.
What am I missing?
Thanks for your time!!!
@ToanDN
What am I missing?
Message 4 of 14
Do you have multiple phases? What are the elements with the concrete material?
Message 5 of 14
in reply to: ToanDN
all materials are "cast in place concrete C25", and the elements are beams, columns, slabs and foundation slabs, stairs.
There are no phases.
Regards!
Regards!
Message 6 of 14
If you add the Category column to the schedule, do you see any categories are missing?  How did you come up with the 533 m3 figure?
Message 7 of 14
in reply to: ToanDN
I found where Revit doesn't properly summon volumes:
1. Floors (Grand total is 5m3)???
2. Structural Foundations
Grand total is 4m3???
So, after summoning I have around 550m3 as it should be.
Why is this happening? Is this a bug?
Regards!
Regards!
Message 8 of 14
4 and 5 are Count Totals, not Volume Totals.  You need to go to Format tab and set the Volume filed to Calculate Totals.
Message 9 of 14
in reply to: ToanDN
@ToanDN
ah...that's the problem,.....my mistake...
Thank you so much!
Regards!
@ToanDN
Thank you so much!
Regards!
Message 10 of 14
in reply to: ToanDN
How to do that so it shows volume?
Message 11 of 14
RDAOU
RDAOU
Message 12 of 14
in reply to: RDAOU
@RDAOU Thank you!
@RDAOU Thank you!
Message 13 of 14
in reply to: RDAOU
Not sure that I know how to accept this as a solution: can't see this option
Message 14 of 14
RDAOU
RDAOU
@Anonymous
You can only accept solutions on Posts which you start...Moreover, there is already a solution for this post 🙂 so all is good .
@Anonymous
