Concatenation of Parameters within a Family
Morning/Afternoon All
I have a number if families, which have "IF" Functions to trigger the Lookup Tables. I've seen on here a number of threads regarding concatenation, is the available?
I would like to create a lookup string based on a parameter for instance:
Concatenate("This is the Start of the String", Parameter A, "This is the end of the String")
Example:
Concatenate("MechanicalFittingFlangeCollarType", Type,"BSEN1092") Where Type = 33.
Result: "MechanicalFittingFlangeCollarType33BSEN1092"
Ilic.Andrej
You can nest a generic annotation family that has a label driven by multiple parameters of the parent family.
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
@Ilic.Andrej unfortunately this wont work as I am trying to gain a string that will identify a look up table from the parameters.
It is not available -- but it is one of the top ten thread topics in my estimation. I think you might even come across one I posted years ago.
@barthbradley Yes I've seen it here a number of times but never managed to see the resolve. Making a long winded IF Function it a bit cumbersome, when it could be done by concatenation of a couple of text strings and a Parameter.
@autodesk @revit Any chance this is on the Roadmap for Improvements
Lachlan-JWP
Best way is to go to the Revit Ideas forum and give for support to an existing idea.
https://forums.autodesk.com/t5/revit-ideas/idb-p/302
