Concatenate two parameters?
clausneergaard
Message 1 of 22
clausneergaard
Hello all -
I am wondering if there's anybody out there that is aware of a way to concatenate(?) two shared parameters, both defined as text fields.
For instance;
Parameter 1 [text]: "Hello"
Parameter 2 [text]: "all"
New parameter (with the concatenation);
Parameter 3 [text]: Parameter 1 + Parameter 2
...this would give me a Parameter 3 with the data "Hello all", correct? Is there a way to do this?
Thanks in advance. Any help is appreciated.
/Claus
Replies (21)
Message 21 of 22
DJSCRIPTS
hello, can you not concate two text parameters in revit 2022 any more? I am getting the error message "improper use of boolean functions" only which is strange because they are all text parameters and no booleans or if/then statements were used. ie: code = Tier 1_Strut Length_Code+Tier 1_Strut Length_Code when both are text but concate in the family does not work. I couldve swarn it did previously. please advise.
Message 22 of 22
DJSCRIPTS
why would you need the third step? is this only in the project environment you are talking about?
