Giving unique element mark workflow
11 ANTWORTEN 11
Nachricht 1 von 12
XXalessio.amodioXX
741 Aufrufe, 11 Antworten
Hi all,
As the title I would like to give unique element mark to structural elements e.g. Structural columns.
They might differ by not only family and type, but by corbel elevation, corbel dimentions, embeded plates elevation an dimentions ....
I actually use schedule, sorting by type,then sort by main dimentions and volume, but sometimes there are so many variants it is impossible to give uniqie mark.
My question is if you have any tip or trick to mark element uniquely.
11 ANTWORTEN 11
Nachricht 2 von 12
als Antwort auf: XXalessio.amodioXX
That why God invented Shared Parameters. Or was it Autodesk? Anyways, Shared Parameters sounds like the answer to your prayers
Nachricht 3 von 12
XXalessio.amodioXX
als Antwort auf: barthbradley
Can you make a pratical example in order to show your workflow?
Nachricht 4 von 12
XXalessio.amodioXX
How would you mark uniquely those elements?
Nachricht 5 von 12
RobDraw
What is this mark being used for?
Rob
Nachricht 6 von 12
XXalessio.amodioXX
als Antwort auf: RobDraw
The mark is used for Tag elements in views plus scheduling elements of same category for bills of quantity. Futhermore i prefer use mark for filtering the exact elements i want to.
For those reason i would like to give unique marks to elements.
Nachricht 7 von 12
RobDraw
Do these unique marks have any meaning other than for identification purposes?
Rob
Nachricht 8 von 12
XXalessio.amodioXX
Identification puroses connected to element e.g. Strucural column MARK= C1 ...
Nachricht 9 von 12
Sounds to me like you need to 'generate' your mark for every column?
I would suggest using Dynamo for this, but maybe some feature that is in Revit that I'm overlooking at this moment...
Just make a list in there, sorted by whatever parameter you want, filter out some you don't need etc. and then just write that into the 'mark' parameter.
Nachricht 10 von 12
You got the point indeed.
I am trying to schedule and use sorting and grouping comand in order to give same mark to exact same elements.
Unfortunatelly the variables are soo numerous that doing  such a work within the schedules is enormous.
Nachricht 11 von 12
RobDraw
If you are going to have the same value for identical elemnts, they are not unique.
Personally, I would not use the Mark parameter and instead use my own parameter but that's just me. If you want the same ID for identical elements, I think something like a type mark would be more appropriate.
Rob
Nachricht 12 von 12
XXalessio.amodioXX
Type mark can be a solution for family with limited type parameter.
Unfortunatelly structural column family with corbels has a lot of Instance parameter e.g. corbel dimentions,elevations..
Not workable for me.
