Hi All -
I understand in Revit 2018 and up you can create a field in a schedule that allows you to concatenate multiple parameters into a single field (Length, Width, and Height into LxWxH, for instance). What I want to do is concatenate the mark numbers of several instances into 1 field.
Lets say I have instances of a family with marks 01, 02, 03, and 04. 01 and 02 have a parameter set to A and 03 and 04 have a parameter set to B. When I create a schedule by the lettered parameter, I want a column to show all instances' marks in that parameter (The row for A would show 01, 02, etc. and the row for B would show 03, 04, etc.).
Is there a way to do that? Thanks very much in advance.
