Hello Everyone,
I'm having an issue with a compound wall behavior in section. I've got two wall types set up. Wall one represents a tile wainscot and wall two the wall base installed below the wainscot. Wall two shows both compound layers and the appropriate cut pattern in section. Wall one, however, does not show either the compound layers or cut pattern but displays the surface pattern of both finish materials. Both walls have the same base constraint and an unconnected height but they differ in the following ways:
Wall One-
Base Offset: 4"
Unconnected Height: 3'8"
Materials:
* Substrate: "FINISH - Grout", 1/16" thick
* Finish 2 (5): "FINISH - Wall Tile, Field", 5/16" thick, Wraps = Yes
* Finish 2 (5): "FINISH - Wall Tile, Bullnose", 5/16" thick, Wraps = Yes
Wall Two-
Base Offset: 0"
Unconnected Height: 4"
Materials:
* Substrate: Adhesive, 1/16" thick
* Sweep: "FINISH - Wall Tile, Cove Base", Cuts Wall = Yes, Cuttable = No
What the heck could be going on?
Thanks in advance for any help!
