Compound wall visibility/behavior issues
lpendergraft
Message 1 of 16
lpendergraft
Hello Everyone,
I'm having an issue with a compound wall behavior in section. I've got two wall types set up. Wall one represents a tile wainscot and wall two the wall base installed below the wainscot. Wall two shows both compound layers and the appropriate cut pattern in section. Wall one, however, does not show either the compound layers or cut pattern but displays the surface pattern of both finish materials.  Both walls have the same base constraint and an unconnected height but they differ in the following ways:
Wall One-
Base Offset: 4"
Unconnected Height: 3'8"
Materials:
 * Substrate: "FINISH - Grout", 1/16" thick
 * Finish 2 (5): "FINISH - Wall Tile, Field", 5/16" thick, Wraps = Yes
 * Finish 2 (5): "FINISH - Wall Tile, Bullnose", 5/16" thick, Wraps = Yes
Wall Two-
Base Offset: 0"
Unconnected Height: 4"
Materials:
 * Substrate: Adhesive, 1/16" thick
 * Sweep: "FINISH - Wall Tile, Cove Base", Cuts Wall = Yes, Cuttable = No
What the heck could be going on?
Thanks in advance for any help!
Replies (15)
Message 2 of 16
Message 3 of 16
Why can't you just have just one wall and split regions in the wall layer configuration to separate the base and the wainscot?
https://help.autodesk.com/view/RVT/2022/ENU/?guid=GUID-50482AF3-42C3-4993-A7B5-EB3E1C17FAE1
Message 4 of 16
lpendergraft
I certainly could do that. I need the wall base on other walls that do not have the wainscot, however so it seemed simpler in this case to seperate them.  Would that be contributing to the problem I'm experiencing?
Message 5 of 16
lpendergraft
They aren't joined.
Message 6 of 16
@lpendergraft wrote:
They aren't joined.
I guess I'm misinterpreting what's going on then. What about creating Parts from Walls?  That resolve?
Message 7 of 16
lpendergraft
Good idea! I tried that too but it told me that it can't make parts out of these elements. So frustrating.
Message 8 of 16
That's odd. A new wrinkle.  Can you share your file?
Message 9 of 16
lpendergraft
Here you go!
Message 10 of 16
This what you are trying to do?
If so, I just overlapped and joined them in the correct order.  Join removes volume at union, so QTOs should be correct.
Message 11 of 16
lpendergraft
That looks perfect! Can you please elborate on what you mean by "overlapped" and "QTO"? What was I doing wrong?
Message 12 of 16
Just drag the upper wall base down a tad so that it overlaps the lower wall.  Then join the two walls together - in the correct order.   That's it.
QTO=Quantity Take-Off.
Message 13 of 16
Message 14 of 16
lpendergraft
That did it. Thank you both so very much (again)!
Message 15 of 16
Great. I'll look forward to receiving that lil' green checkmark.
Message 16 of 16
lpendergraft
