Complex stairs
2 ANTWORTEN 2
Nachricht 1 von 3
542 Aufrufe, 2 Antworten
Complex stairs
I need to draw complex stairs and railing in revit just like shown in picture.
Unfortunately I tried to sketch stair path but it said: Invalid sketch, can't create run by this sketch.
Maybe someone has any advice?
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: Anonymous
Are you using a conventional stair and then converting it into a sketched stair and editing that?  It should work - see attached.
I would suggest doing each run separately.  Create the railing separately as an In-place component.  You can't do it with standard railings.
Nachricht 3 von 3
martijn_pater
I'm also using Archicad, gotta love it for the stairs functionality. Anyway, @Anonymous answer should do the trick I guess...
