Communication Center: How to modify / add RSS-addresses
I can not add or modify the RSS-addresses in communication-center. For example both addresses are defined as "unknown or wrong formatted":
http://feeds.feedburner.com/BimAndBeam?format=xml"
 http://feeds.feedburner.com/typepad/the-building-coder
What to do?
Thanks and regards
Accepted solutions (3)
MichaelSpahn
Hello @Anonymous,
Thank you for your post. Please try these links. That should work.
http://feeds.feedburner.com/typepad/mangonn/bim_beam
Stay hungry, stay foolish!
Viele Grüße,
Michael Spahn
TGA Planer/Konstrukteur
Firmenwebsite | LinkedIn
Ihr fandet einen Beitrag hilfreich? Dann vergebt dafür doch Likes!
Eure Frage wurde erfolgreich gelöst? Dann einfach auf den 'Als Lösung akzeptieren'-Button klicken!
@MichaelSpahn
The Building Coder works fine and shows me current posts.
Bim and beam has new address, but shows old post from 2016 ...
Edit:
Sorry, you used the old address (last post from 2016).
See current address in my first post.
Let's wait until Monday.
MichaelSpahn
Here is the correct Link
Works fine
Viele Grüße,
Michael Spahn
Thanks @MichaelSpahn
