Command which allows you to locate plans on same location on Sheets
Which one is the command or symbol which allows you to locate the floor plans of a multistory building and of each discipline on the same place of a 36" x 36" sheet?
Thanks in advance.
There is no command.  I do it manually:
- Turn on sheet guide grid
- Place a view and move it so a column grid intersection match a guide grid intersection
- Repeat for other sheets
Are you asking how to locate -- as in "find" -- views that have been place on Sheets?  If so, create a View List Schedule.  All the parameters are there to report where the view is located.  You can sort by Discipline too.
loboarch
As was mentioned guide grid is the tool to do this. Here is a video showing the process.
http://help.autodesk.com/view/RVT/2020/ENU/?guid=GUID-73FDE1A3-4F91-46EC-9654-FC4573907D86
Jeff Hanson
Principal Content Experience Designer
Revit Help |
s.borello
Are you talking about the Revit guide grid?  There is an add-in from ideate apps that will do it as well but it's not free.
