Combining three windows as one family
Message 1 of 21
While I was looking for triple windows,
I realized it is better to combine three windows that I have.
Two fixed windows and one operable casement window.
And I wanted to use this combination in the future projects.
Is there anyway to combine two or more families?
I tried nesting families but could not get one.
Please advise.
Replies (20)
Message 2 of 21
Absolutely.  You can nest as many child-windows into one parent-window as you want.  It is a very common approach.
Message 3 of 21
Thanks ToanDN.
I tried nesting families.
So if I don't change the size, it is fine.
But when I change the size it breaks up.
Should I combine those different way if I want to modify each windows?
Message 4 of 21
Oh got it for now.
I missed to lock those two.
So it is not possible to 'EDIT TYPE' nesting families?
Below, selected window is a host family.
Thanks a lot
Message 5 of 21
See the example below.  for nesting family, it is better to use Instance parameters in the child families so you have more flexibility associate parameters in the parent family.
Message 6 of 21
Thanks so much ToanDN.
One more question.
I only cuts the wall in certain height (sill height 0'-0")
How can they cut the wall in every height?
Is it s view range problem?
Thanks again.
Message 7 of 21
Do you mean your View range cut plane is at 0? It should be 4' or around that range.
Message 8 of 21
View range is fine.. I think.
I am not sure what the problem is..
If it is not touching the ground, it fills with the wall color in the background.
It looks fine in 3D view though.
Message 9 of 21
TIP: Make the nested windows SHARED families, that way your Project Schedules will report 'em.
Message 10 of 21
Not sure what is going on.  It works fine here.  See the file.
Message 11 of 21
Some useful information that may be at the heart of your issue: Window & door families are not cut based on the cut plane defined in project views. Instead they are cut based on the cut plane defined in the family's plan view.
 https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
Message 12 of 21
Oh. It was because visual style was Shaded or Consistent Colors.
But is this normal in Shaded mode?
Is there way to make it same as window touching the ground?
Message 13 of 21
Plan Regions is what you need here. Are you familiar with them?
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2015/EN...
Message 14 of 21
Edit teh material so that the shading is white.
Message 15 of 21
italonge
Hi everyone
I was looking for many foruns and videos, but I've not found a good step by step that helped me
I'm having problem when I try to share the parameters to change sizes into project
Actually, I want to make something a little complex, but it will help me a understand a lot about Revit Families
The image below explains better:
There is 4 families: The mirror, counter, sink and faucet and the cabinet
Inside the family file it's ok, there is all parameters, but when I load it in some project, I lost them..
How can I make it editable?
Thank you so much for the help!
Message 16 of 21
Make those child families "shared".
Message 17 of 21
italonge
@ToanDN How to do that?
I'm only see this option around the web, but it doesn't works... Checking "shared" option don't change nothing...
So I guess it's something else that I'm missing
Message 18 of 21
Tick that Shared box then you will have all the parameters of the nested families for scheduling, and be able to tag them individually in project.
Message 19 of 21
italonge
Well, doesn't worked... I think I didn't not explain very well
Again I'd loaded two existing families in a Metric Generic Model
Inside this file it's ok, but when I load this into a project, I can't edit their parameters...
I'm trying to transform those existing parametes in shared parameters, but nothing works!
But the different tag worked fine...
Message 20 of 21
Well the parameters can be seen and reported. To modify them in project, you need to associate them with parameters of the host family. Do a search in "associate nested family parameters".
