combine multiple object as single element
Hello
is it a way to combine multiple elements as single object, and volume object if it’s also possible?
The goal is to allow exchange data between Revit & cad system to insert for instance Hvac defined in Revit as a single volume part into Cad assemblies and not many elements as allow IFC format who require an unecessary long time of translation process.
if not it could be a great enhancement to extend collaboration between Bim & Industrial Design.
regards
steve
Avaris.
Yes you could make a simple family and attach parameters to it. That way you create a simple graphic representation and have a more extensive textual part. You could also have multiple graphic representations in one family (coarse, medium and fine). For export to IFC you could use the coarse graphic represenations.
