Combine Files into 1 file
I'm french so sorry if it's not good ^^
I'm working with families, I got a lot of files of the same object but with different lenght.
I would like to make just 1 file with the possibility to change the lenght by choosing the "type of family".
Thank you 🙂
bimscape
You're going to need to add dimensions and parameters (to those dimensions) within the family. You can then create different "Types"- each one having a different set of values for those parameters. We would really need to see the family in question (and know which dims you need to be variable) to evaluate how complex a task this is going to be for you.
Kind regards,
Ian
Author of The Complete Beginners' Guide to Autodesk Revit Architecture (free online course)
Ilic.Andrej
Do you think it would be easier for you if you post your question on french forum?
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
