Hi I'm done with my model but I need to put it in a submission template and I can't seem to be able to do it. My submission is in 2 days. Urgent!!!!
What do you mean by "Submission Template"? The term "Template" can mean a couple of different things in Revit.
How do you need it be presented?
Basically there's a template file which they want me to submit in as they have done the views, the schedules, the sheet as to how they want it to be. Hence, how do I input this in my working file?
Basically this: https://www.corenet.gov.sg/general/building-information-modeling-(bim)-e-submission.aspx
Under that website the file name is: Revit 2016 Template (v2.1 NEW)
So, I'm done with my working file and I don't know how to link them up or upload it in my file
Hi
Template file is nothing but a initial file to start with..
Ex: Architectural template, Default Construction etc..
Save the template file...( RTE File ) R - Revit , TE - Template
Create new Project Using that Template File ...
so now you should get a new file ( Revit , RVT )..
here you copy paste your work, I think your submission needs to be in this file now..
and thats it..once you copy paste your work here, the sheet set up which exists in already should get updated...
Give it a try.
Cheers
hello, open your project revit file and your submission template and go to manage > use project transfer standard to your revit file. thanks
