Column not Going to Base Constraint
BigPicture045
BigPicture045
I need these columns to go to the given constraint. Currently, they are stopping at the walls. The column in the front which goes to the floor is correct.  Cut geometry not available for column to wall.
Joined? Reverse Join Order.
