- Mute
- Permalink
- Report
Hello.
I have a problem when drawing columns (or beams) inside walls. In certain conditions the column looks fine with the gray fill inside going over the wall's fill, sometimes instead the column border are shown, but with no gray fill inside (the material properties are the same, with gray solid fill as section and projection, plus the column family has the "pre-cut in views" option checked).
I figured out that:
- the this occurs when the column touches the beams in its top
- changing materials doesn't fix this issue
- chaning the view properties like level of detail or view range doesn't fix this either
I'll post some screenshots for better unterstanding.
Thanks for the help
I'm using Revit LT 2020.2
